Предлагаю в этой теме делиться понравившимися вам пресетами ( выкладывайте milk + скриншот)
Milkdrop Forum Dump (50,315 presets)This is a file dump of every preset that was publicly released on the Milkdrop Forum from 2001 to 2019. Lots of junk in there, but some real gems too. Beware of extremely offensive language in some of the filenames.
Cream of the Crop (9,795 presets)I spent 7 months curating through 50,315 presets from the Milkdrop community, selecting only the best ones, and then organized them into categories/subcategories. It was a mammoth task and well worth the effort.
Isosceles Mashups 2020 (1,131 presets)Here are some my own presets that I created using the mashup technique.
Isosceles Mashups 2024 (986 presets)To make it easier to quickly browse this collection of presets, I choose to not organize these presets into the typical categories that I utilized for prior releases. So is this a mixed bag? Absolutely. But I live by the motto that one person's trash is another person's treasure. So dive in and pick out the gems that speak to you.
Spout Jamming (11,912 presets) When Spout Jamming, I've found that many of the presets are too intense and wished that I could access just the core shaders. I gave it some thought and realized that I could manually disable the "Waves" and "Shapes" layers of a preset to address this. Then I opened up the preset in a text editor and further realized that I could do a find-and-replace to automatically disable these layers for a whole collection of presets. So I collected all of the presets from the Cream of the Crop, Isosceles Mashups 2020, and Isosceles Mashups 2024 packs into a new collection with these layers disabled.It's impossible to know how each preset will react to these tweaks since each preset is designed differently. The only way is to experiment and find out. But you'll likely find that some of these presets are trash and some are gems, but it depends on the Spout video stream that you're injecting into NestDrop.Full transparency, I've been hesitant to release these presets since they only function when injecting a Spout video stream into NestDrop. These presets have been stripped down to their bare essentials and are meant for advanced users that understand how to use Spout Sprites within NestDrop. Hence the following warning, if you use these presets for any other purpose then they will frequently render out pure black visuals.
Во-первых, автор - не я.Во-вторых, нет уверенности, что проблема именно в OpenGL-обвязке.В-третьих, на Linux-е нет DirectX
большой MilkDrop 130k+ Presets MegaPack
У меня только MC 591 работает как на видео.При 588 плеер перевод плагин в unstable.
Аналогично.
