As I tested, it did happen on Two-Line play style.
Can you allow resizing and scroll lyrics window for lyrics without timings?
Do you mean playing lyrics with no timestamp?
It is already implemented in 1.2.5. Do you experience any issues?
yesIt show only first string
Can you share your lrc file? The lrc parser is totally written from scratch by me, though I write unit tests, it may still have some issues, so it would be great help if you can share your lrc file
I was wrongThe text is not time-synchronized.I want to see the entire text at onceand be able to scroll manuallyand resize the window
1.2.5after the start of a new track, the lyrics from the previous track remain in the windownew track have no lyrics
The issue is addressed in ver.1.2.5.1, alongside some optimizations for Two-Line play style.
v1.2.5.1Lyrics with no timestamp, Two-Line play style: don't show lyrics
1. One-Line play style2. Play file with Lyrics with no timestamp - i see lyrics3. Set Two-Line play style - i see lyrics4. Playback - stop (NOT pause)5. Play file with Lyrics with no timestamp - i do NOT see lyrics (first line)After some time, text appears on the second line
Are you enabled "hide if no lyrics" preference?
1. Emiliana, it's been so long since you texted me2. I finally took a break and now I feel like I'm on ecstasy3. You say what my work means to me will one day be the death of me4. They tried to kill me once, but, darling, you just resurrected meEmiliana, it's been so long since you texted meI finally took a break and now I feel like I'm on ecstasyYou say what my work means to me will one day be the death of meThey tried to kill me once, but, darling, you just resurrected meEmiliana, it's been so long since you texted meI finally took a break and now I feel like I'm on ecstasyYou say what my work means to me will one day be the death of meThey tried to kill me once, but, darling, you just resurrected me
[aimp_floating_lyrics_plugin]LyricsWindowOpened=0PlayStyle=3MultiLineScroll.InactiveLineOpacity=0FadeInOutPlayer.LetterSpacingAnimationSpeed=0TextShadowEnabled=1TextShadow=#FFAC5555,2,2,5TextStrokeEnabled=0TextStroke=1,#FFFFFFFFFontFamily=Segoe UI,Segoe UIFontSize=50FontColor=#FFB4B438FontWeight=400LetterSpacing=0BackgroundColor=#A03F85BEBorderFeatherWidth=0.800000011920929LyricsWindowClickThrough=0LyricsWindowHideWhenNoLyrics=0LyricsWindowAlwaysHideTaskbar=0FadeInOutPlayer.FadeDuration=500TwoLinePlayer.Reverse=0TwoLinePlayer.Gap=0TwoLinePlayer.FadeDuration=1000LyricsWindowRect=471,555,1000,120
NoMy problem video:https://skrinshoter.ru/vc3XKiZQmsLSee to end.I do not see first string of lyricsLyrics for test (music file with embedded tag):Code: [Select]1. Emiliana, it's been so long since you texted me2. I finally took a break and now I feel like I'm on ecstasy3. You say what my work means to me will one day be the death of me4. They tried to kill me once, but, darling, you just resurrected meEmiliana, it's been so long since you texted meI finally took a break and now I feel like I'm on ecstasyYou say what my work means to me will one day be the death of meThey tried to kill me once, but, darling, you just resurrected meEmiliana, it's been so long since you texted meI finally took a break and now I feel like I'm on ecstasyYou say what my work means to me will one day be the death of meThey tried to kill me once, but, darling, you just resurrected meSettings:Code: [Select][aimp_floating_lyrics_plugin]LyricsWindowOpened=0PlayStyle=3MultiLineScroll.InactiveLineOpacity=0FadeInOutPlayer.LetterSpacingAnimationSpeed=0TextShadowEnabled=1TextShadow=#FFAC5555,2,2,5TextStrokeEnabled=0TextStroke=1,#FFFFFFFFFontFamily=Segoe UI,Segoe UIFontSize=50FontColor=#FFB4B438FontWeight=400LetterSpacing=0BackgroundColor=#A03F85BEBorderFeatherWidth=0.800000011920929LyricsWindowClickThrough=0LyricsWindowHideWhenNoLyrics=0LyricsWindowAlwaysHideTaskbar=0FadeInOutPlayer.FadeDuration=500TwoLinePlayer.Reverse=0TwoLinePlayer.Gap=0TwoLinePlayer.FadeDuration=1000LyricsWindowRect=471,555,1000,120
