谢谢提醒,试过仍然没有用,6.0压根不显示此插件可以使用。即使删除了上面两行代码,在软件运行后插件目录下看到此插件,想打勾让其运行仍然提示,有部件没找到。我是win10操作系统。AIMP官方最新的6.0版本。测试无效。已经提前安装了runtime的32&64位版本。附件上传了出错界面与错误提示。目前此插件仅在5.40.2721版本上生效,我已经亲测过了,AIMP v6.00.3071 Beta 4系列无效。
确保.net 8.0 runtime安装了,下载链接在一楼,选择对应的runtime下载安装即可。
In love with this plugin!If I only knew it existed earlier!! I now use it to have time synced lyrics on my OBS overlay when I stream music for my friends while in VR! https://youtu.be/J4OiCIT-PQoHowever, there's a few suggestions I've got that would probably improve experience when using this awesome plugin!I observed the plugin will display lyrics regardless if they're synced or not, can we have a toggle so only time synced lyrics show up in the window?I'd be awesome, so that way if I lack the timestaps it doesn't show some random part of the song based solely on duration.Another thing that'd be awesome is if the window can be set to always show behind (so that way, it's more like a widget on the desktop, than an overlay on top of everything I do!)Since I personally use it for my OBS stream, it'll help to avoid the annoying rectangle that OBS causes windows 10 to show around the window when captured, which can't be turned off.Keep being awesome, thanks for this! :D
我第一件事就是安装了runtime 32&64bit两个版本。但是在win10上此插件安装无效。
你好,不要着急,可否发一下你的:1. windows 10系统具体版本(如windows11 24H2 OS Build 26100.7171,可使用winver命令查看);2. Edge浏览器的版本(如144)。注意到你是在windows 10下的AIMP6无法使用,我会尝试安装一个和你相同版本的windows系统并进行测试的;目前如果不影响的话可以继续使用AIMP5,我会尽可能确保插件兼容最新版本的AIMP播放器,谢谢 :)
win10版本: 10.0.19045.6466 edge版本是: 149.0.4022.98 64bit你也可以直接来到我的群里下载我的AIMP全插件强化版本:651525551Q群哈。试试看我的版本在你的win11里面能不能直接安装此插件。入群回答:独行浪客
