It seems you had been using the plugin before runtimes were installed, so AIMP may be disabled the plugin due to loading failure. To fix this, close AIMP instance, open "AIMP.ini" file within "[your-AIMP-installation-directory]/Profile" directory, search and delete these lines (it may differ from your file, but should look similar):[Plugins]aimp_floating_lyrics.dll=0[Plugins.CachedInfo]aimp_floating_lyrics.dll=0|||||1552900961Try launching AIMP after that, plugin should work now.
I get answers.It conflicts with another plugin I am using. 【AutoLyric6.3.0_setup.exe】Picture 2:Using the plugin, the desktop lyrics are still absent.Sorry to have caused you so much trouble.I think I'll stick with "AutoLyric6.3.0_setup.exe" or another "AimpDesktopLyricsCpp.zip" plugin, as it's simple and easy to use.It is very user-friendly for beginners.
Plugin1.2.1 AIMP5.40 Windows101. Lyrics are displayed even when the option is not enabled.2. The lyric control area can be moved separately from the lyrics.3. Error when attempting to edit lyrics.4. Player crashes after closing the lyrics editing window.Video: https://skrinshoter.ru/vboS7gcwRS9
sorry, my badit's another pluginYour plugin doesn't show lyrics at allOther points remain relevant:1. Plugin doesn't show lyrics at all2. Error when attempting to edit lyrics.3. Player crashes after closing the lyrics editing window.New video without another plugins: https://skrinshoter.ru/vboZGUfacu9
lso, it looks like you are using a beta version of AIMP(v5.40.2675 beta, I couldn't find a place to download this version)
Could you please try with a clean installation of AIMP player and see if the issues still exist? Also, it looks like you are using a beta version of AIMP(v5.40.2675 beta, I couldn't find a place to download this version), can you also try with latest stable version(v5.40.2716)? Thank you for your time!
I'm use v5.40.2716 x64Clean installation + plugin v1.2.1: all the issues still exist
System.Generics.Collections.TList<apiPlayer.IAIMPExtensionPlayerHook> x 1, AIMP.PlaybackController.Services.TAIMPPlayerService x 1, AIMP.Core.Services.Adapters.Classes.TAIMPStringAdapter x 9, AIMP.Actions.Services.Adapters.TAIMPMenuPlaceHolderAdapter x 2, AIMP.Actions.Services.Adapters.TAIMPMenuItemAdapter x 2, AIMP.Actions.Services.Adapters.TAIMPActionAdapter x 4AIMP.PlaybackController.Services.TAIMPPlayableFileInfoAdapter x 5
First, the transparent float window is not transparent for mouse clicks.Here is a small video that illustrates the issue: https://disk.yandex.ru/i/CHWmk4a8lNkp2w I'm trying to select a song to play but fail because the mouse pointer clicks are transferred to an invisible (transparent) lyrics window.Next, plugin does not show lyrics text if lyrics has no timestamps:https://disk.yandex.ru/i/CHWmk4a8lNkp2wIf think, in this case, would be better to show lyrics like MiniLyrics does (it scrolls the entire text due entire track duration)Last, this may lead to memory issues:https://disk.yandex.ru/i/3hfPoKfmd1Q7FwAs I can see something are incorrect with with reference counting of interfaces (May be you miss some AddRef/Release calls) on plugin's side.Code: [Select]System.Generics.Collections.TList<apiPlayer.IAIMPExtensionPlayerHook> x 1, AIMP.PlaybackController.Services.TAIMPPlayerService x 1, AIMP.Core.Services.Adapters.Classes.TAIMPStringAdapter x 9, AIMP.Actions.Services.Adapters.TAIMPMenuPlaceHolderAdapter x 2, AIMP.Actions.Services.Adapters.TAIMPMenuItemAdapter x 2, AIMP.Actions.Services.Adapters.TAIMPActionAdapter x 4AIMP.PlaybackController.Services.TAIMPPlayableFileInfoAdapter x 5Please, check operations with the IAIMPExtensionPlayerHook, IAIMPServicePlayer, IAIMPString, IAIMPMenuItem, IAIMPAction and IAIMPFileInfo.If you want, I can share debug version of app that reports about all memory issues on exit.
2. Here I got a verbose build of my plugin in attachment, this one will always open a console window when launching and output useful information, could you please install this verbose build and share the console's outputs with me (a video including the console window is appreciated)?
1. Can you open windows Event Viewer(right-click window icon on task bar - select Event Viewer), try to find any "Application Error" or ".NET Runtime" entries about "AIMP"(especially ".NET Runtime" ones), and share what it said to me?
Video: https://skrinshoter.ru/vbpWx3anUDr
Thanks, it's really helpful! One last thing, if you are willing to, can you share the lrc file of that song named ⌊ 2095 ⌉ ?
