What sort of template? Where i can check those?
I tried everything, every combination of settings and templates, its still the same, this thing is bugged. Too bad, on a pc it runs like a charm.
after i add/remove few folders, it starts to add them with the tracks in reverse order, last track is first on the list and first last.
I managed to pull the log with ADB platform tools, the same tools i used to install aimp on the tv box.
Do as you ask? You asked for a log file? I provided one. It is with yesterdays date and time, exactly after i enabled logging in About, as YOU ASKED. It was the only file with .log extension that was in the the files list, and if this one is incorrect, and since i clearly said before that i am having trouble finding it (and took the effort to find A log file that is aptly named Debug.log), instead of acting like a prick, it would have been nice if you actually TOLD me WHICH exact log file you want and where i can find it. I also took my sweet time to give you feedback about how to reproduce this issue that is obviously a bug, and now i am starting to regret that. I don't care anymore.
