AIMP for Android v4.30
Files are added in reverse order
Topic: Files are added in reverse order (Read 3931 times)
January 20, 2026, 18:47:30 »
Marko_Panajotov
Hello, i am using the newest version of AIMP on android tvbox for playing music on my smartTV/Hi-Fi set. The problem i have is that when i add new files in the playlist, it adds them in reverse order, even though the reverse order is not selected in the sorting options.
Any help would be appreciated. Thanks.
Edit: I just checked, this is happening only when i add files/folders while there are already files added in the playlist. When i clear the playlist, and then add files/folders, it adds them in the correct order.
Re: Files are added in reverse order
January 21, 2026, 07:58:17 »
Карма: +3187/-76
May be, you've selected some sort by template
January 21, 2026, 22:51:08 »
Marko_Panajotov
What sort of template? Where i can check those?
January 21, 2026, 23:01:37 »
Карма: +3187/-76
Quote from: Marko_Panajotov on January 21, 2026, 22:51:08
Refer to "sort by" menu of playlist screen
