CDDB lookup not working for audio cds in v4.70, build 2227
All
Topic: CDDB lookup not working for audio cds in v4.70, build 2227 (Read 15224 times)
September 14, 2020, 07:42:31 »
g12345567
Running latest AIMP v4.70, build 2227 and when I insert an audio CD to play the cd information is is not displayed. Just shows the following instead of going off to the internet database and displaying the disc info. CD name, artist and track names for the inserted Audio CD.
Audio Track 1
Audio Track 2
Audio Tracl 3
ETC
Compact Disk Digital Audio Plugin is enabled. May have turned off CDDB lookup in the past but and if I did I can't see any settings related to this or how to enable.
Re: CDDB lookup not working for audio cds in v4.70, build 2227
September 14, 2020, 08:19:11 »
Карма: +3224/-78
Yep, the FreeDB service is dead. We will replace it via Musicbrainz in next update.
Of course, you can download
nightly build
and try it now.
December 11, 2020, 20:16:14 »
Dsquared
Was the switch to MusicBrainz completed? I do not see AIMP in the list of players (
https://musicbrainz.org/doc/MusicBrainz_Enabled_Applications
) supporting MusicBainz.
December 11, 2020, 21:01:59 »
Карма: +3224/-78
Yes, it completed.
December 11, 2020, 22:29:09 »
Dsquared
Thank you for answering. I am having problems with AIMP retrieving the proper information for a 3 CD album. I am using V4.70.2236 in windows 10 64 bit. When I put CD 1 in, AIMP correctly retrieves that CD info and artwork. When I place CD 2 or CD 3 in the computer AIMP only shows the file info for CD 1 and the correct artwork. Is there somewhere to see if AIMP is correctly pointing at MusicBrainz or do I need another plugin?
Thanks again
December 11, 2020, 22:36:18 »
Карма: +3224/-78
Can you send to me a logs from these disc that generate the following tool:
https://yadi.sk/d/ebXDa4iNPBKbiQ
December 11, 2020, 23:11:59 »
Dsquared
Here are the log files of all 3 CD's.
December 17, 2020, 18:44:57 »
Dsquared
Is there any news on this issue?
Reply #8 on:
December 17, 2020, 19:30:39 »
Карма: +3224/-78
Oh, looks like I miss you answer. I will check the log today. Thank you.
Reply #9 on:
December 17, 2020, 19:37:56 »
Карма: +3224/-78
How you adding the files to a playlist? Via the "Add CD" menu item or like a local files?
Reply #10 on:
December 17, 2020, 20:10:32 »
Dsquared
I am not sure I understand your question. I have tried 1) going to the Menu > Open Files (and selecting all the files) opening all the files on the CD and 2) right clicking in playlist area >Add > Files (and selecting all the files).
In all cases AIMP shows the correct album cover but always the songs from CD !. CD ! and 2 have 18 songs each but CD 3 has 10 songs. When I put in CD 2 AIMP shows the songs from CD 1. In the case of playing CD 3, AIMP shows the first 10 songs of CD 1.
I do not see an "Add CD" in the AIMP menu.
Reply #11 on:
December 17, 2020, 21:13:37 »
Карма: +3224/-78
So, it displays incorrect data in playlist only or for playing track too?
Reply #12 on:
December 17, 2020, 23:36:00 »
Dsquared
The playlist and the track playing
both
display the incorrect information when I play either CD 2 or CD 3.
Reply #13 on:
December 17, 2020, 23:51:05 »
Dsquared
So I do not know if this helps but I ripped the files with EAC V1.6 and it downloads the correct CD info for CD's 2 and 3. This corresponds to the log files which appear to show 3 different CDs.
Then I tried a different 2 CD album in AIMP and it correctly retrieved both CD's information.
Is the problem unique to this 3 CD album?
Reply #14 on:
December 18, 2020, 00:09:05 »
Карма: +3224/-78
I think our audio converter will load info for all CDs correctly too. I think that issue in a file info cache system, because files has same names and paths, but different physical drives. So, player does not take this fact into account.
All
