CDDB lookup not working for audio cds in v4.70, build 2227
Pages:
All
Topic: CDDB lookup not working for audio cds in v4.70, build 2227 (Read 15287 times)
Re: CDDB lookup not working for audio cds in v4.70, build 2227
Reply #15 on:
May 21, 2021, 14:55:04 »
NDS-801
Just ran into this problem with several 2-CD albums - first CD is read correctly, second CD shows the information of the first/previous CD.
Updated to the latest version (V 4.70, build 2250 / 19.5.2021)
The "Compact Disk Digital Audio Plugin" is active.
Tried to find something in the options that may prevent the cache to be emptied or the CD informations being read correctly - couldn't find anything.
Added the CDs using different methods (1. Explorer - Open - select & right-click files, "Open with AIMP" / 2. Use AIMP menu "Add" > CD/DVD) (Choosing "Play" directly from the drive icon in the Windows Explorer side menu always opens the Windows Media Player, which I'm not able to change to use AIMP as my default player for CDs...
Restarted AIMP - no difference.
Restarted my machine - no difference.
Any news on this issue?
Reply #16 on:
April 04, 2023, 22:45:19 »
PegHorse
Hi
Running v5.11 and facing exactly the same issue.
The plugin is enabled too.
Thanks
With VLC, i managed to get title using this server : freedb.freac.org
Last Edit: April 04, 2023, 22:57:14 by PegHorse
Reply #17 on:
January 24, 2025, 15:58:05 »
PegHorse
Please help me to identify my Audio CD.
Reply #18 on:
January 24, 2025, 16:12:15 »
Карма: +3227/-78
FreeDB service is dead.
Reply #19 on:
January 24, 2025, 19:24:49 »
PegHorse
Then use another service ? Musicbrainz ? AccurateRIP ?
Reply #20 on:
January 26, 2025, 19:37:53 »
Карма: +3227/-78
Quote from: PegHorse on January 24, 2025, 19:24:49
Musicbrainz is already supported, but disk must have a musicbrainz id
Pages:
All
