Skins in the development stage
Kr1eger
Sony FH-215R
Pages:
All
Topic: Sony FH-215R (Read 2404 times)
Re: [NO ML] Sony FH-215R
Reply #15 on:
November 06, 2026, 00:00:16 »
faraon 20
здравствуйте сделайте пожалуйста что бы можно было растягивать скин
Reply #16 on:
November 07, 2026, 08:28:54 »
ss.pl
Карма: +168/-10
m4r6i0
, если продолжительность трека более 100 минут, то счетчик не отображает секунды.
If the track duration is more than 100 minutes, the counter does not display seconds.
Если изменить цветовую схему (3094), то не отображается кассета.
If you change the color scheme, the cassette is not displayed.
Reply #17 on:
November 10, 2026, 22:53:14 »
m4r6i0
Карма: +3/-0
Thank you all for testing! Version 1.5 fixes everything reported:
Soolo - "PHONO isn't working": you were right. The skin had no Music Library window, so AIMP disabled the key. v1.5 adds one: PHONO now opens the "PS-LX Turntable / Music Library" window (a turntable on top that spins while playing, the library below, resizable). The PHONO lamp in the FUNCTION INDICATOR lights while it is open. This should also answer the [NO ML] tag.
ss.pl - tracks longer than 100 minutes: the counters now switch to 6 digits (000:00) for those tracks, on the tuner and on the deck.
ss.pl - Custom color scheme hid the cassette (AIMP 6): fixed. A fully transparent click area over the cassette window was being painted black by the color scheme.
faraon 20 - stretching: the playlist and the new library window can now be resized in width and height. The other windows are fixed-size copies of the real units, but they scale with AIMP's Scale Factor (Options > Interface): v1.5 has textures drawn for 150% and 200%, so they stay sharp. Which window did you want to stretch?
Also: on first start the windows are now centered as a group, so they fit a 1920x1080 screen.
Download v1.5:
Sony FH-215R v1.5.acs5
(12 MB) Project:
Sony FH-215R v1.5.acs5proj
(144 MB)
Спасибо всем за тесты! Версия 1.5 исправляет всё, о чём сообщили:
Soolo — «PHONO не работает»: вы правы. В скине не было окна фонотеки (Music Library), поэтому AIMP отключал кнопку. В 1.5 оно добавлено: PHONO открывает окно «PS-LX Turntable / Music Library» (сверху проигрыватель, диск вращается во время воспроизведения, ниже фонотека, размер окна меняется). Пока окно открыто, горит индикатор PHONO. Это также должно снять пометку [NO ML].
ss.pl — треки длиннее 100 минут: счётчики тюнера и деки для таких треков переходят на 6 цифр (000:00).
ss.pl — пользовательская цветовая схема скрывала кассету (AIMP 6): исправлено. Полностью прозрачная область клика над окном кассеты закрашивалась чёрным.
faraon 20 — растягивание: плейлист и новое окно фонотеки теперь растягиваются по ширине и высоте. Остальные окна — копии настоящих блоков с фиксированным размером, но они масштабируются через «Масштаб» AIMP (Настройки > Интерфейс): в 1.5 есть текстуры для 150% и 200%, поэтому они остаются чёткими. Какое окно вы хотели растянуть?
Также: при первом запуске окна теперь центрируются группой и помещаются на экран 1920x1080.
Скачать 1.5:
(12 МБ) Проект:
(144 МБ)
Reply #18 on:
November 11, 2026, 11:24:56 »
Карма: +1411/-191
Where are the tabs?
Pages:
All
Kr1eger
Sony FH-215R
