[x] [3086] [Linux] [Fedora] Error loading custom skin when launching AIMP
Topic: [x] [3086] [Linux] [Fedora] Error loading custom skin when launching AIMP (Read 547 times)
September 27, 2026, 19:16:38 »
user1-audiophile
I use the black onix two skin which can be found here:
https://aimp.ru/?do=catalog&os=desktop&id=0&keywords=black%20onix%20two&pagesize=20
Starting version 3086, Every time I launch AIMP, I get a window with an error message loading the custom skin (see screenshot) and the default skin loads instead.
After that I can change to black onix two in skin settings and it loads fine. But then after I quit AIMP and launch it, the error appears again and the default skin loads.
I haven't tried other custom skins.
Last Edit: September 28, 2026, 16:56:13 by Artem
Re: [3086] [Linux] [Fedora] Error loading custom skin when launching AIMP
September 28, 2026, 12:41:11 »
adem
Карма: +5/-0
1. Please share some OS/DE info. You can just copy-past it from AIMP > About > small button near «Linux / Fedora...»
2. Also can you attach the settings folder from "/.config/AIMP/" to this topic?
3. Make a backup of your settings folder at "/.config/AIMP/", clean up "/.config/AIMP/Skins/" folder. And install
Black Onix Two
skin once more. Does it resolves the issue?
Re: [?] [3086] [Linux] [Fedora] Error loading custom skin when launching AIMP
September 28, 2026, 16:56:09 »
Карма: +3239/-85
Thanks, fixed!
