[x] [2725] [x64] AIMP: System Error. Code: 1400. Invalid window handle
Topic: [x] [2725] [x64] AIMP: System Error. Code: 1400. Invalid window handle (Read 718 times)
August 30, 2026, 19:50:57 »
Dimon911
Карма: +1/-0
Hi,
for the first time get an error with AIMP. Was able to reproduce it!
Tested with v5.40.2703 and v5.40.2725 (both on win64).
How to reproduce:
1. AIMP is playing something..
2. Select a few 4-6 items on playlist
3. Right click and choose "Spectrum analysis.."
3a. Here the main window of AIMP can be in foreground or not, the behavior is slightly different. I use "dock to left screen side" and " floating with auto-hide mode"
4. After processing is done, select an item/items in the result table to show "Analysis Results" graphs
5. Close the window with table results (all Analysis Results windows will be closed too).
6a. If AIMP window was in auto-hide mode, try to "unhide" it with the arrow on screen side by clicking with mouse on it.
6b. If AIMP window was visible all the time during the close of table with results try to close main AIMP window.
The error could be reproduced all the time with this instruction steps.
Very small (probably not scaled) error "window" is attached.
Last Edit: September 01, 2026, 15:54:00 by Artem
Re: [2725][Win64] AIMP: System Error. Code: 1400. Invalid window handle.
August 31, 2026, 08:03:33 »
Карма: +3227/-78
What version of Spectralyzer plugin you uses?
Re: [?] [2725] [x64] AIMP: System Error. Code: 1400. Invalid window handle.
August 31, 2026, 17:13:24 »
Dimon911
Карма: +1/-0
Quote from: Artem on August 31, 2026, 08:03:33
The currently last one. Spectralyzer v2.13.34
https://aimp.ru/forum/index.php?topic=49548.0
May also be important to reproduce:
A4 skin is used. V 3.2
https://aimp.ru/forum/index.php?topic=54154.0
September 01, 2026, 15:53:56 »
Карма: +3227/-78
Thanks. I've reproduced that. I will update the app soon.
