Skins in the development stage
Kr1eger
Multipass [AIMP5.40]
Topic: Multipass [AIMP5.40] (Read 883 times)
July 21, 2026, 00:33:19 »
raul
Завсегдатай
Карма: +14/-0
Another "iconic" modern Winamp skin, now for AIMP.
Originally created by R. Peter Clark, so credit to him (Peter) for the textures and Keltic Danor via XMPlay Support for the main window texture (and fonts).
Please install the "XMPLAYtinyblue.ttf" font (inside the .zip file you downloaded) before using it, or else the scrolling song name's font will not load properly.
UPDATES, July 26th 2026: Scrolling song title font is now in .ttf format, since the skin can't recognize the font after you installed it. I also changed the font to this new .ttf font I recently converted.
UPDATES, July 30th 2026: Fixing "stop playback" button, "VID" button is now "VIS" button, fixing media library tabs menu button.
UPDATES, July 31st 2026: Added quick file info and new "Carbon" variant of this skin.
UPDATES, August 2nd 2026: Fixing library, visualizer and playlist window bar (above the screen and below the titlebar), adding drop wheel and centering "VIS" button title.
UPDATES, August 3rd 2026: Removing "stopped playback" peaks, because the Winamp spectrum analyzer's behavior is different than AIMP's.
UPDATES, August 5th 2026: Didn't knew that the visualizer window on the original Winamp skin has a shadow bar after the "VISUALIZER" title, so I added it (Regular Multipass only).
Last Edit: August 05, 2026, 22:33:20 by raul
Kr1eger
