AUR package will be installed: aimp -> 6.00.3064-1 [outofdate: 2026/05/26]🚛 Proceed with installation? [Y/n] 🚛 [v]iew package details [m]anually select packages🚛 [r] show if packages are required by already installed packages>> looking for conflicting AUR packages...🚛 warning: Not showing diff for aimp package (installing for the first time)Do you want to edit PKGBUILD for aimp package? [Y/n] nReading local package database...🚛 Starting the build:==> Making package: aimp 6.00.3064-1 (Fri 29 May 2026 06:13:31 AM PDT)==> Checking runtime dependencies...==> Checking buildtime dependencies...==> Retrieving sources... -> Downloading aimp-6.00-3064b-x86_64.pkg.tar.zst... % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed100 273 0 273 0 0 260 0 00:01 0100 26263 0 26263 0 0 16086 0 00:01 0 -> Found changelog==> Validating source files with sha256sums... aimp-6.00-3064b-x86_64.pkg.tar.zst ... FAILED changelog ... Passed==> ERROR: One or more files did not pass the validity check!Command 'sudo --user=#1000 -- makepkg --force' failed to execute.
Can someone please check the AUR version?
