[+] [3056] [Linux] AIMP: Pin window position not working as expected
Topic: [+] [3056] [Linux] AIMP: Pin window position not working as expected (Read 1190 times)
April 28, 2026, 10:59:38 »
nicky
Arch Linux Plasma 6.6.4 Wayland
Qt 6.11.0
AIMP while on windows with option "Pin window position" is enabled on the "Information Box" window, we can move the main AIMP window and the "Information Box" window together, and this is the expected behavior, but AIMP on the linux version, "Pin window position" on the "Information Box" window is weird and it act like there's two separate window instead, main AIMP window and the "Information Box" window they just don't move together when dragging.
Last Edit: April 28, 2026, 13:12:06 by Artem
Re: [3056][Linux] AIMP: Pin window position not working as expected
April 28, 2026, 11:03:25 »
nicky
here is the expected behavior on windows AIMP
https://imgur.com/KRBBxZs
and this is the linux AIMP, the pin window position is very weird
https://imgur.com/a/PtMyElg
April 28, 2026, 13:11:56 »
Карма: +3240/-85
To move glued windows, start dragging the window holding the shift key. In this case, AIMP will use it own drag-move implementation instead of native one
