How can I replace “, ” (with a space) with “;”?
Topic: How can I replace “, ” (with a space) with “;”? (Read 858 times)
March 21, 2026, 18:56:42 »
genzlod
I’ve been using AIMP and the Tag Editor for quite some time.
Code:
[Select]
=%ReplaceEx(%Value,/ ,;,/,;)
This function has been very useful for replacing “/ ” (with the space) and “/” for “;”, but it doesn’t seem to work the same way with commas because AIMP uses them as separators. Is there any way to do this?. To tell AIMP to replace the comma as-is instead of using it as a separator.
(translated from Spanish).
Re: How can I replace “, ” (with a space) with “;”?
March 21, 2026, 20:03:20 »
Карма: +474/-74
Use the function "char". Code = 44.
Read more...
March 21, 2026, 20:09:14 »
Карма: +474/-74
The system also has a character table. You'll just have to use a calculator (another tool) to convert hex to decimal.
Read more...
March 21, 2026, 21:09:23 »
genzlod
Thank you, bro! I didn't know about the %Char function; it's so handy
