[x64] AutoEQ for AIMP - Automatic Equalizer based on Genre/Artist [AIMP5.40]
Topic: [x64] AutoEQ for AIMP - Automatic Equalizer based on Genre/Artist [AIMP5.40] (Read 4848 times)
February 04, 2026, 18:40:08 »
troyanoj
Карма: +1/-0
Hello AIMP Community!
The Story Behind AutoEQ
AutoEQ began as a deeply personal project. My only goal was to enjoy my music to the fullest, creating a tool that could understand every rhythm and adjust itself perfectly for my ears. However, after seeing the results—how it transformed the listening experience and made AIMP truly come alive—I realized I couldn't keep this to myself. I had to share it with the world.
This plugin is the result of several months of hard work, sleepless nights, and sacrifice. It was born out of passion, and I’ve poured my heart into making it a piece of software that brings your music to life. If you find value in this work and appreciate the effort behind it, please consider supporting its continued development. Your appreciation is what keeps this project alive.
Key Features:
Smart EQ: Automatically enables the AIMP Equalizer when a profile is matched.
Global Genre Support: Over 20+ built-in profiles including Rock, Pop, Metal, Jazz, Blues, Classical, Ska, Reggae, and more.
Hybrid Detection: Uses local metadata first, with a smart Last.fm fallback for unknown tracks.
Spanish/Latin Specialist: Built-in recognition for Spanish Pop, Rock en Español, and Regional Mexican music.
💡 Pro Tips for Best Performance:
Clean Metadata: The plugin works best (and fastest) if your files have correct Artist and Genre tags. If your collection is tagged, the plugin applies the EQ instantly without internet lookups.
Manual Tagging: If a song isn't being recognized correctly, you can manually set its Genre in AIMP (Tag Editor). The plugin will detect your manual changes immediately!
Requirements
AIMP v5.40 or higher.
Windows (64-bit version recommended).
Support the Developer
If you enjoy this plugin and would like to support its continued development, you can make a voluntary donation here:
Ko-fi: ko-fi.com/jaimefsa
PayPal: paypal.me/JaimeFSA
Developed by S. Jaime (troyanoj) for the AIMP community. Enjoy your music!
How to install:
Create a folder named AutoEQ inside your AIMP Plugins directory.
Copy
├── 📄 AutoEQ.dll
├── 📄 AutoEQ.ini
├── 📄 Readme.txt
└── 📁 resources/ into that folder.
Restart AIMP and enable it in Preferences > Plugins.
Download:
Last Edit: February 05, 2026, 15:38:07 by Soolo
