Suggestions
Precision Input for Playback Speed & Pitch
Poll
Ваше мнение / What do you think?
За / I need this option too
4 (66.7%)
Меня устраивает текущая реализация / I like current implementation
2 (33.3%)
Total Members Voted:
6
Topic: Precision Input for Playback Speed & Pitch (Read 7158 times)
January 24, 2026, 20:57:02 »
SargeK
In the app’s equalizer, I really appreciate the ability to adjust dB levels both with the slider and by tapping to enter a precise value via the keyboard. This is very handy for fine-tuning.
However, I’ve noticed this precision input option isn’t available in the playback speed section. Currently, trying to set the speed in small increments (e.g., 0.01x) using the slider is difficult, as the value often shifts slightly when lifting my finger, making it hard to land on the exact setting I want.
My suggestion:
Allow the user to tap on the labels "Pitch: 0.0st" and "Playback Speed: 1.00x" to open a numeric input dialog, similar to the equalizer’s keyboard input. This dialog should include Reset, Cancel, and Accept/OK buttons to match the existing user experience.
This would bring much-needed precision to speed and pitch adjustments and create a consistent, intuitive interaction pattern across the app.
Thanks for considering this improvement!
Re: Precision Input for Playback Speed & Pitch
January 29, 2026, 21:56:47 »
dimkadel
Карма: +4/-2
just sorry for my english.
why for this change will be usefull?
we have ± 5% switch now. it's cover all usability for listening. 1 percent step or digital input is overkill. this my own opinion.
March 27, 2026, 19:59:28 »
Walther.7070
I am a researcher, I totally need precision playback input control.
If I need to set playback speed to 0.81, 0.82 is useless to me, and the slider makes it a real pain to be precise frequently.
I came to these forums to request this same feature, and noticed this thread.
Please add this.
Suggestions
