AIMP for Android v4.30
Suggestions
No resample mode
Poll
Ваше мнение? / What do you think?
За / I need this option too
3 (75%)
Нейтрален / I don't care
1 (25%)
Против / Useless fo me
0 (0%)
Total Members Voted:
4
Topic: No resample mode (Read 6340 times)
No resample mode
November 26, 2025, 20:11:48 »
Luckymehra990
Завсегдатай
Карма: +4/-2
Audiophile.
"No resample mode" in Players refers to a feature request that would allow the app to output audio at the exact same sample rate as the source file, rather than upsampling it to a single rate. This mode, sometimes called "output-matches-source" or "adaptive sampling," is primarily useful for users with external USB DACs or Digital Audio Players (DAPs) and is not a current feature in the app. The current default behavior upsamples all audio to a single rate, which some users find can degrade audio quality.
What it is: "No resample mode" is the ability to set the output sample rate to match the source file's sample rate. For example, a 44.1kHz song would be played at 44.1kHz, and a 96kHz song at 96kHz.
44.1kHz ==> 44.1kHz
96kHz ==> 96kHz
192kHz ==> 192kHz
Currently in development (For more detailed explanation only e.g only used for example):
https://forum.powerampapp.com/ideas/idea/40-no-resample-mode-sometimes-referred-to-as-output-matches-source-or-incorrectly-as-bit-perfect-for-usb-dacsdaps-aka-usb-exclusive-mode/
As AIMP4 supports it an option to disable it simply i need, saves CPU/Battery/RAM cycles without unnecessarily wasting it.
Re: No resample mode
November 26, 2025, 21:09:59 »
Карма: +3196/-76
We already discussed this feature. Please search on forum
Suggestions
No resample mode
