I'd prefer if AIMP didn't adjust the volume automatically at all.
So, switch off the volume normalization options
I'm not using any Equalization, and I do not have any sound effects enabled (like replay gain or peak normalization - everything is turned off).
Check MusicFX settings too, may be something on OS sound effects produces this effect
Do you have an idea where I find those settings on Android?I went through all the audio settings on my device, but couldn't find anything that made me think it could be the culprit.
Main Menu \ Sound Effects \ FX button
