[x] [1563] Android export Playlist with absolute file paths
Topic: [x] [1563] Android export Playlist with absolute file paths (Read 8050 times)
June 05, 2025, 10:49:40 »
Hubertus
Hi,
i am use AIMP for Windows and android. In Windows i can save the playlists with the option "absolute file paths" off. Wenn i export the changed playlist from android this option not exist - so i have to correct the filepath manually.
is it posible to get this option in AIMP for Android too?
Thanks
Hubertus
Last Edit: June 05, 2025, 13:19:24 by Artem
Re: Android export Playlist with absolute file paths
June 05, 2025, 12:33:32 »
Карма: +3210/-78
Mobile version should always save playlists with relative file paths.
June 05, 2025, 12:34:16 »
Карма: +3210/-78
Oh, it seems like a bug, because relative paths does not works for M3U export, but works correctly with XSPF.
Re: [x] [1563] Android export Playlist with absolute file paths
June 05, 2025, 17:44:49 »
Hubertus
Clear, but i need the option to save the playlist without the relative path so i can use it parallel in windows
June 06, 2025, 08:12:34 »
Карма: +3210/-78
Quote from: Hubertus on June 05, 2025, 17:44:49
But this is current behavior for M3U playlist format. Anyway, mount path of sdcard may differs from one android to another.
