AIMP for Android v4.30
AIMP doesn't save window position
Topic: AIMP doesn't save window position (Read 10632 times)
January 26, 2025, 04:03:15 »
Vitriol
Hello,
I have 2k resolution monitor on Display Port. Second screen (TV) is disabled/unplugged from HDMI.
If monitor wakes up from stand-by or I turn it on, AIMP changes position slightly as it can be seen in the screenshot attached.
If I exit full-screen games it reduces the size of the playlist so I have to re-adjust it every time. A bit annoying.
Latest version. Does anybody know how to fix this?
Thank you.
Re: AIMP doesn't save window position
January 26, 2025, 19:43:28 »
Карма: +3193/-76
What is your app version?
January 26, 2025, 22:02:20 »
Vitriol
Latest; v5.40.2655
Same issue was happening on the previous version, so I updated it to the latest.
I think main problem is that I switched to/added 32" 2k (100% scale) monitor, moving on from 1080p (125% scale) 37" TV.
I never had that issue on the old screen. It was connected through HDMI, now Display Port. I'm thinking AIMP "remembered" old scaling, so I'm assuming clean remove/install would help perhaps?
January 29, 2025, 22:15:23 »
Карма: +3193/-76
Please, try this build:
https://disk.yandex.ru/d/iTI6JMG5wwJAzA
