Suggestions
Add the ability to disable remembering playback speed
Poll
Ваше мнение / What do you think?
За / I need this option too
2 (50%)
Нейтрален / I don't care
1 (25%)
Против / Don't do that!
1 (25%)
Total Members Voted:
4
Topic: Add the ability to disable remembering playback speed (Read 7178 times)
January 23, 2025, 17:57:58 »
xeo
Карма: +20/-0
When we set a different playback speed, we usually do it for one file. For example, I play podcast file (only voice) with 1,10 speed, then I want to switch to music file which is played at a bad speed and have to be reset manually (if noticed).
Add the ability to disable remembering playback speed. In this window something like "Remember setting" option could be added, so it can be enabled or disabled.
Last Edit: February 06, 2025, 19:13:45 by xeo
Suggestions
