Установка deb
Topic: Установка deb (Read 2834 times)
Установка deb
December 15, 2024, 08:24:40 »
Самсоненко Вячеслав
Операционная система: Debian 12, со всеми последними обновлениями, на 2024-12-15
Установка, в соответствии с описанием на странице
https://www.aimp.ru/?do=download&os=linux
> sudo apt -y install ./aimp_5.30-2563_amd64.deb
отрабатывает с ошибкой:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'aimp' instead of './aimp_5.30-2563_amd64.deb'
The following additional packages will be installed:
fonts-wine libasound2-plugins libcapi20-3 libosmesa6 libwine libz-mingw-w64 wine wine64
Suggested packages:
cups-bsd ttf-mscorefonts-installer q4wine winbind winetricks playonlinux wine-binfmt dosbox exe-thumbnailer | kio-extras wine64-preloader
Recommended packages:
wine32
The following NEW packages will be installed:
aimp fonts-wine libasound2-plugins libcapi20-3 libosmesa6 libwine libz-mingw-w64 wine wine64
0 upgraded, 9 newly installed, 0 to remove and 0 not upgraded.
Need to get 104 MB/124 MB of archives.
After this operation, 698 MB of additional disk space will be used.
Get:1 /home/svm-admin/Downloads/aimp_5.30-2563_amd64.deb aimp amd64 5.30 [20.2 MB]
Get:2
http://deb.debian.org/debian
bookworm/main amd64 libcapi20-3 amd64 1:3.27-3+b1 [28.5 kB]
Get:3
bookworm/main amd64 libz-mingw-w64 all 1.2.13+dfsg-1 [152 kB]
Get:4
bookworm/main amd64 libwine amd64 8.0~repack-4 [100 MB]
Get:5
bookworm/main amd64 wine64 amd64 8.0~repack-4 [248 kB]
Get:6
bookworm/main amd64 wine all 8.0~repack-4 [70.6 kB]
Get:7
bookworm/main amd64 fonts-wine all 8.0~repack-4 [193 kB]
Get:8
bookworm/main amd64 libasound2-plugins amd64 1.2.7.1-1 [75.2 kB]
Get:9
bookworm/main amd64 libosmesa6 amd64 22.3.6-1+deb12u1 [2,905 kB]
Fetched 104 MB in 2s (45.1 MB/s)
Selecting previously unselected package libcapi20-3:amd64.
(Reading database ... 197592 files and directories currently installed.)
Preparing to unpack .../libcapi20-3_1%3a3.27-3+b1_amd64.deb ...
Unpacking libcapi20-3:amd64 (1:3.27-3+b1) ...
Selecting previously unselected package libz-mingw-w64.
Preparing to unpack .../libz-mingw-w64_1.2.13+dfsg-1_all.deb ...
Unpacking libz-mingw-w64 (1.2.13+dfsg-1) ...
Selecting previously unselected package libwine:amd64.
Preparing to unpack .../libwine_8.0~repack-4_amd64.deb ...
Unpacking libwine:amd64 (8.0~repack-4) ...
Selecting previously unselected package wine64.
Preparing to unpack .../wine64_8.0~repack-4_amd64.deb ...
Unpacking wine64 (8.0~repack-4) ...
Selecting previously unselected package wine.
Preparing to unpack .../wine_8.0~repack-4_all.deb ...
Unpacking wine (8.0~repack-4) ...
Setting up libcapi20-3:amd64 (1:3.27-3+b1) ...
Setting up libz-mingw-w64 (1.2.13+dfsg-1) ...
Setting up libwine:amd64 (8.0~repack-4) ...
Setting up wine64 (8.0~repack-4) ...
Setting up wine (8.0~repack-4) ...
Selecting previously unselected package aimp.
(Reading database ... 198503 files and directories currently installed.)
Preparing to unpack .../aimp_5.30-2563_amd64.deb ...
Unpacking aimp (5.30) ...
Selecting previously unselected package fonts-wine.
Preparing to unpack .../fonts-wine_8.0~repack-4_all.deb ...
Unpacking fonts-wine (8.0~repack-4) ...
Selecting previously unselected package libasound2-plugins:amd64.
Preparing to unpack .../libasound2-plugins_1.2.7.1-1_amd64.deb ...
Unpacking libasound2-plugins:amd64 (1.2.7.1-1) ...
Selecting previously unselected package libosmesa6:amd64.
Preparing to unpack .../libosmesa6_22.3.6-1+deb12u1_amd64.deb ...
Unpacking libosmesa6:amd64 (22.3.6-1+deb12u1) ...
Setting up libasound2-plugins:amd64 (1.2.7.1-1) ...
Setting up aimp (5.30) ...
Setting up fonts-wine (8.0~repack-4) ...
Setting up libosmesa6:amd64 (22.3.6-1+deb12u1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.36-9+deb12u9) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for wine (8.0~repack-4) ...
N: Download is performed unsandboxed as root as file '/home/svm-admin/Downloads/aimp_5.30-2563_amd64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
Переход в root ошибку не устраняет.
Соответственно, при запуске всё криво и с ошибками.
Re: Установка deb
December 15, 2024, 08:50:00 »
Карма: +3219/-78
Эм, а мы здесь причём?
Re: Установка deb
December 15, 2024, 12:20:44 »
Карма: +473/-73
https://askubuntu.com/questions/908800/what-does-this-apt-error-message-download-is-performed-unsandboxed-as-root
Судя по обсуждению, проблема с тем, как вы используете терминальные команды.
На сайте плеера не указано, что нужно использовать указанную вами команду для установки. Тем более, указано, что об ошибках следует писать в определённом месте, а не создавать новые темы.
Re: Установка deb
December 15, 2024, 19:59:43 »
Карма: +3219/-78
Это Линукс, там всегда все не просто. Тут явно проблема в разрешениях
Установка deb
