Visualizations
VFD LCD WINAMP PLUGIN WINAMP MUSIC VISUALIZATION
Topic: VFD LCD WINAMP PLUGIN WINAMP MUSIC VISUALIZATION (Read 8824 times)
October 31, 2024, 20:18:52 »
LordVader
VFD LCD WINAMP PLUGIN WINAMP MUSIC VISUALIZATION does not work fully, I get song titles and track bar but no visualisation.
I have attached pictures of what should be there and what I am getting.
Any help will be appreciated
The program that drives the LCD is called LCD Studio and works perfectly with the Winamp DLLS.
Re: VFD LCD WINAMP PLUGIN WINAMP MUSIC VISUALIZATION
October 31, 2024, 20:36:25 »
Карма: +473/-73
If the plugin is for Winamp, then it uses the Winamp API, i.e. not the AIMP API. It is acceptable to expect that compatibility is not guaranteed.
The last and only request for VFD I see was 12 years ago, so the hope of getting a solution in the form of advice or a new plugin is at a near-zero level.
https://www.aimp.ru/forum/index.php?topic=31850
November 04, 2024, 22:03:01 »
LordVader
How do I use the Winamp API? I have no clue how to achieve that.
I am prepared to offer £25 if someone can get it working. The track name and the song progress bar work.
November 05, 2024, 04:50:46 »
CkopoxoD
Карма: +149/-1
1. Install
AIMP Winamp Wrapper 0.2
(forum
topic
2. Make sure the plugin is enabled
Preferences \ Plugins
3. Open the visualization window, switch to AIMP Winamp Wrapper 0.2, left-click in the middle
Visualizations
4. Select "Load Plugin..." and navigate to the LcdStudio directory. Switch to "All DLL files" and open "WinampNative.dll"
If done correctly, LCDStudio will begin to receive data
Spectrum
November 05, 2024, 05:23:39 »
CkopoxoD
Карма: +149/-1
Similar for LCD Smartie, but on step 4 you will need winamp_lcdsmartie.dll from
Winamp Spectrum Analyzer Plugin
LCDSmartie
November 05, 2024, 17:35:36 »
LordVader
I am failing, I have switched skins but do not get the option to make sure the plugin is enabled to select the Winamp Is it possible to share your AIMP version folder online (Filefront or equivalent?). I would be very grateful
November 05, 2024, 18:42:34 »
CkopoxoD
Карма: +149/-1
Quote from: LordVader on November 05, 2024, 17:35:36
I am failing
Are you using 64-bit AIMP?
AIMP Winamp Wrapper 0.2 plugin is 32-bit only, so you need to install the appropriate AIMP.
November 05, 2024, 20:35:07 »
LordVader
It works now, but not with the technics skin, I guess you can't have everything in life and I must be grateful it works now as intended with a few basic skins.
Many thanks for all your help
I am indebted to you.
Last Edit: November 07, 2024, 20:30:13 by LordVader
Reply #8 on:
April 02, 2025, 23:14:34 »
LordVader
Is there a way to use dual visualization plugging simultaneously? I have noticed that in some skins, the visualisations do not work For example in screenshots in the previous post.
Visualizations
