How to remove the message about not existing library?
Topic: How to remove the message about not existing library? (Read 6956 times)
September 26, 2024, 22:25:26 »
rado84
Карма: +3/-4
Bulgarian
Recently my microSD card died, so I replaced it with a new one which works perfectly, AIMP reads it OK, as it should. But ever since I put the new microSD card in the phone, AIMP for Android keeps showing this message when I open the app - see the attached screenshot.
So, how do I make this message go away?
AIMP version is 4.11.1467 (08.09.2024), arm64-v8a, api33. That's the version according AIMP itself by clicking the "i" icon.
Re: How to remove the message about not existing library?
September 27, 2024, 08:32:30 »
Карма: +3220/-78
Refer to app settings \ my music and remove the path from paths for indexing
September 27, 2024, 14:06:06 »
rado84
Карма: +3/-4
Bulgarian
When I go to "My Music/Folders" and click on the 3-dotted menu for each path (or hold my finger directly on each path), these are the options I get and there's no "remove".
Edit: I found it where it was, but it wasn't where you suggested. When I go to "My Music/Folder", I had to tap the horizontal 3-dotted menu where I was able to remove the old path and add the new SD card. You should have mentioned that because the obvious thing anyone would do would be to tap the vertical 3-dotted menu, not the horizontal one.
