using AIMP intents with key mapper?
Topic: using AIMP intents with key mapper? (Read 6078 times)
September 19, 2024, 11:14:33 »
Toffie
I'd like to use AIMP intents with key mapper to map a double click on my headphones to an addToFavorites action.
I found
https://www.aimp.ru/forum/index.php?topic=68605.0
which showed a list of available intents.
If I try to use this with key mapper with the com.aimp.service.action.addToBookmarks Action (see attach) I get following error in the log file :
Failed to perform action Intent(description=add to favorites in aimp, target=ACTIVITY, uri=#Intent;action=com.aimp.service.action.addToBookmarks;end), reason: android.content.ActivityNotFoundException: No Activity found to handle Intent
I'm using version 4.11.1467. Is it possible the intent is no longer or via a different way available?
Re: using AIMP intents with key mapper?
September 19, 2024, 11:19:48 »
Карма: +3230/-79
Quote from: Toffie on September 19, 2024, 11:14:33
target=ACTIVITY
You should send intent to a background service, not to activity
