Suggestions
Crossfade more than two tracks (like PC's version does)
Poll
Ваше мнение? / What do you think?
За / I need this option too
0 (0%)
Нейтрален / I don't care
2 (100%)
Против / Useless fo me
0 (0%)
Total Members Voted:
2
Topic: Crossfade more than two tracks (like PC's version does) (Read 17799 times)
November 11, 2023, 20:41:58 »
Walther.7070
Example, queue:
Song A: 2:00 duration
Song B: 2:00 duration
Song C: 2:00 duration
Crossfade value: 10 seconds.
How to trigger:
Press "Next" song on time 1:45 of the Song A while playing, and this happens:
1:45: Song B starts playing (fade in), Song A starts fading out.
1:50: Song A's audio is cut, Song B starts fading out, Song C starts fading in.
2:00: Song B's fade out finishes, Song C is playing at full volume
Expected result:
1:55: Song A's fade out finishes, Song B is playing at full volume.
My device: Xiaomi Redmi Note 11S, MIUI 14.0.3 Global.
Last Edit: November 12, 2023, 10:38:35 by Artem
Re: [1381] Auto-change track triggers after Manual-change if crossfades overlap
November 12, 2023, 10:38:04 »
Карма: +3228/-78
Yes, mobile app (unlike PC's version) can cross-fade only two tracks. I've moved your report to suggestions.
Re: Crossfade more than two tracks (like PC's version does)
December 15, 2023, 05:47:30 »
Walther.7070
That.... wasn't the bug I was talking about.
Okay, yes, it's something AIMP lacks, but I was talking about this other bug:
1. Press "next song"
2. AIMP skips "two" tracks, instead of one.
That one is still a bug that needs fixing. Do I open a new thread to address it?
December 15, 2023, 08:18:21 »
Карма: +3228/-78
Refer to the "About" dialog of the app, and check the "enable logging" option. Restart the app. Now, reproduce an issue and send the log file to me. Please, report to me a approximate time when issue was happened.
December 26, 2023, 10:37:19 »
Walther.7070
+Artem
@Artem
I can't figure out how to mention your name. I sent a PM with the information, but the size limit is 20k characters, so I had to cut off a lot of the log. Here I attach it in its entirety.
Timestamp 26/12/2023 02:10:19.612 is when I pressed next (track change from "Prologue of Fate" into "Followers of Darkness").
Timestamp 26/12/2023 02:10:24.073 is when AIMP skips to the next (track change from "Followers of Darkness" into "Baljhet Mountains").
I use 18 seconds as crossfade configuration.
December 26, 2023, 16:36:16 »
Карма: +3228/-78
As I can see in log, you have tap the next button during crossfading effect (So, player already started the next song and you ask it to jump next again)
Suggestions
