Is there a way to display a single folder icon for the entire playlist?
Topic: Is there a way to display a single folder icon for the entire playlist? (Read 6301 times)
October 12, 2023, 02:46:51 »
FolderIcons
Tried adding folder.ico and folder.png files in the same folder as all of the .mp3 files that the .m3u8 text file points to and it imports them all correctly and saves them as a playlist but it does not also show the single icon of that type of music that is the icon of the type of music it is playing. Which is what the folder.ico or folder.png is trying to do.
Is there a way to have it just show the only .png or .ico file in that folder on the main phone screen as well when it is playing that specific playlist (and then change to a different image when you change playlists)?
There is no album art. Just want it to display the folder.ico or folder.png (or could do different filenames) but something so you can easily tell what "station" AKA playlist you are currently playing.
Amazing software and might be missing something minor but not able to get that to quite work yet and it might just not be an available feature at the moment?
I guess I could technically add the same ico / png file to every mp3 file in each playlist and that might work? Not exactly the ideal way of doing that though since just trying to display the folder icon if the files in that playlist do not have an image of their own.
Re: Is there a way to display a single folder icon for the entire playlist?
October 12, 2023, 08:12:21 »
Карма: +3229/-78
I afraid it impossible for now
