Playlist Naming for Streams
Topic: Playlist Naming for Streams (Read 2537 times)
August 07, 2023, 09:09:46 »
NoxMorbis
When I create a playlist for a stream, it has a place where you can name it. However, as soon as the stream starts to play, it populates the name with the first song played information.
I just want stream playlists to show the stream URL and, if possible, the name of the station only, static.
e.g.
Smooth Jazz Add Free
http://smoothjazz.cdnstream1.com/2585_320.mp3
Can I do that?
Re: Playlist Naming for Streams
August 07, 2023, 09:18:20 »
Карма: +1406/-190
Playlist - Lock from changes
August 07, 2023, 20:12:57 »
NoxMorbis
Quote from: Soolo on August 07, 2023, 09:18:20
Awesome. Now, is that anyway to get the original name back without deleting/recreating the playlist streams and reapply the "lock" parameter?
I found it. Thanks!
This is a kind of strange way to have to do that naming, but I guess given the way the program is coded it makes perfect sense, and doesn't require additional coding.
However, it seems it might be nice to have a section where you can change and toggle off and on the playlist name vs streaming information.
Last Edit: August 07, 2023, 20:25:18 by NoxMorbis
