If you double-click a music file on your PC to open it in AIMP, it will keep getting duplicated and added to your playlist, even though it's the same music file with the same path.Is there any way to ensure that the same music file is only added once?
I'm not able to add the same song twice in a playlist, is there any configuration that releases this feature?
PC's version doesn't have this limitation
I use android...I tried to edit the playlist manually, but it doesn't load the same song twice in the same playlist
