[x] [1250] "Find missed files" does not find files
Topic: [x] [1250] "Find missed files" does not find files (Read 10394 times)
April 19, 2023, 04:18:59 »
B10Reaper
My favorites playlist keeps losing multiple music files whenever a folder change happens. I go to options > find missed files, I point it to the folder the files are in, and it gives a "operation successfully completed" but it never actually fixes the missing files.
I've checked for app updates as well as OS updates.
Is there any way to fix this or am I stuck re-adding files every time?
Last Edit: April 26, 2023, 16:05:42 by Artem
Re: "Find missed files" does not find files
April 19, 2023, 08:41:21 »
Карма: +3241/-85
What exactly happened with the original files? Are they moved, renamed or replaced by different format?
April 19, 2023, 08:43:46 »
B10Reaper
Moved folders, otherwise untouched.
Re: [1250] "Find missed files" does not find files
April 19, 2023, 09:44:23 »
Карма: +3241/-85
Please, try on following build:
https://disk.yandex.ru/d/c5G1MoDPusyYug
(I've added few logging entries for this action).
Next, refer to the "About" dialog of the app, and check the "enable logging" option. Now, reproduce an issue and send the log file to me.
Re: [?] [1250] "Find missed files" does not find files
April 20, 2023, 02:45:40 »
B10Reaper
https://linksharing.samsungcloud.com/aWOEg7CGeMed
Here is a link to the log.
What I had done was before I had the music in subfolders. I then moved everything into one big folder and thought AIMP would find them, but no such luck. If there's anything else you need me to do, please let me know. Thanks!
April 20, 2023, 09:50:57 »
Карма: +3241/-85
Thanks for a log, it seems that duration and file size of missed playlist items and discovered files are not match. Please, can you make a screenshot of playlist screen with missed files? Does it have correct duration in it?
April 20, 2023, 22:23:50 »
B10Reaper
Strange, the duration shouldn't have changed. On the favorites screen the files show a duration of 0:00 so I'm not 100%. There's a decent amount of them in the favorites, but the 2 at the top are an example of what it shows.
April 26, 2023, 16:05:39 »
Карма: +3241/-85
In latest beta version
, I've improved the "find missed files" functionality. Now, it should works in this case too
Re: [x] [1250] "Find missed files" does not find files
Reply #8 on:
April 28, 2023, 22:57:54 »
B10Reaper
Works great so far, thank you! I had one issue so far where I got a warning it was overloading the CPU in my phone (I turned logging on and I'll open a topic if it happens again) but I like the new interface and the cache option makes a huge difference.
Thank you!
