Suggestions
Multiple Playlist Selection filter same songs in selected playlists
Poll
Ваше мнение? / What do you think?
За / I need this option too
0 (0%)
Нейтрален / I don't care
0 (0%)
Против / Useless fo me
0 (0%)
Total Members Voted:
0
Topic: Multiple Playlist Selection filter same songs in selected playlists (Read 10401 times)
April 15, 2023, 18:29:52 »
Excalibur
I hope I'm submitting this correctly this time... I read the rules and used the search and didn't find my idea, I don't read Russian and I'm new here. thanks!
My new feature idea is to be able to select multiple playlists, and have AIMP show you and filter all of the songs that are the same in the playlists selected.
This allows you to filter your music by your playlists you've made. an example of this would be;
to select my "piano" playlists and my "soft emotional" playlist. Now it will only show me the songs that are the in both of those playlists that are the same, I'll be left with my "soft/emotional piano songs" and I can listen to them there.
hope this make sense!
I attached a photo for a visual representation.
Last Edit: April 19, 2023, 08:39:12 by Artem
Re: Unique new Feature idea for an update
April 15, 2023, 19:55:39 »
Карма: +1408/-191
Reed the rules
https://www.aimp.ru/forum/index.php?topic=39349.0
Re: Multiple Playlist Selection filter same songs in selected playlists
April 17, 2023, 10:52:15 »
Карма: +3229/-78
I think that the "send to new playlist" command in playlists manager should solve the case. I will implement in next build of AIMP4
Re: [Запланирова]Multiple Playlist Selection filter same songs in selected playlists
April 19, 2023, 00:51:04 »
Excalibur
Hello thank you for the response, here is an update to my post as I feel I may have not explained my idea well enough the first time, sorry...
to be clear this is not making a new playlist or combining them, but filtering the common songs between selected playlists into a temporary spot to listen to. I have my playlists categorized by genre and emotion, so to be able to select multiple playlists and listen to only the common songs between them would be an AMAZING and simple feature to filter songs!
Hopes this makes sense! I believe it would be a great feature for mobile and PC
Thanks again!
April 19, 2023, 08:38:59 »
Карма: +3229/-78
Oh, I misunderstand you
April 20, 2023, 03:55:13 »
Excalibur
I do apologize, I didn't do a great job explaining my idea... instead I made a detailed photo explaining it better, this is my last try I don't want to keep bugging you hahah.
I'm not sure if it would be too much to implement a whole new feature like this or not, but I leave it in your hands.
thanks! I appreciate all of the replies
Suggestions
