[x] [1241] Broken folder/file sorting inside playlist?
Topic: [x] [1241] Broken folder/file sorting inside playlist? (Read 9355 times)
January 15, 2023, 04:14:58 »
s/ash
Карма: +34/-1
I don't know if this is a bug or intended. I have the following
folder structure
(folders containing other folders do not contain any files). I am adding the entire
Genshin Impact
parent folder to an empty playlist.
AIMP 3.20, using
these settings
, generates
this playlist
. This is good, this is what I want.
AIMP 3.30, using
these settings
, generates
this playlist
. I don't understand why they are not sorted properly like on AIMP 3.20.
AIMP 3.30 using
the same settings as AIMP 3.20
places each individual file
in its own group
, by that I mean it creates a group for each file individually, ending up with the group count = file count.
The files within each folder are named
01. File name.flac
02. File name.flac
22. File name.flac
This seems broken to me, but if it's intended behaviour can you please tell me which settings should I make to have AIMP 3.30 behave just like AIMP 3.20 did?
Last Edit: January 15, 2023, 14:48:19 by Artem
Re: [1241] Broken folder/file sorting inside playlist?
January 15, 2023, 14:48:14 »
Карма: +3233/-81
Try this build:
https://disk.yandex.ru/d/mjmowcOKtAPBnA
Re: [x] [1241] Broken folder/file sorting inside playlist?
January 15, 2023, 15:39:50 »
s/ash
Карма: +34/-1
Thank you! It works.
