Can anyone recommend a skin that allows album art to be displayed
Topic: Can anyone recommend a skin that allows album art to be displayed (Read 6229 times)
December 08, 2022, 18:39:43 »
Milton
I'm new to the forum. I love AIMP player and have experimented with various skins, but so far have not found one that allows album art to be displayed. Any suggestions would be appreciated.
Thanks
Milton
Re: Can anyone recommend a skin that allows album art to be displayed
December 08, 2022, 20:30:14 »
sveakul
Карма: +81/-1
Even the default Bliss 4K skin will do that, but you need to drop Menu and check "Visualizations" which activates a new, movable window; right-click inside of that and choose "Album Art." You can do that with the "Modern" skin also. AIMP 5.03 Bliss 4K example:
December 08, 2022, 22:52:09 »
Milton
Thank you sveakul for your quick reply, and suggestion. I'll give it a try.
December 18, 2022, 04:13:34 »
Greenball
Sorry for the bad english. I used a translator.
AndroEvolution
https://www.aimp.ru/?do=catalog&rec_id=1016
or OraMulih
https://www.aimp.ru/?do=catalog&rec_id=614
If you, like me, don't like the separated movable window, maybe you wanna try these two. With both of them you can set in the skin editor if you want to have the album cover displayed as background of the "now playing"- and/or "playlist"-window (with ocopacity settings too).
I am always in the playlist window, and see the cover nicely.
December 26, 2022, 22:13:47 »
JD79
I'd recommend
https://www.aimp.ru/?do=catalog&rec_id=163
