When or How Directsound?
Topic: When or How Directsound? (Read 5358 times)
October 13, 2022, 01:44:03 »
beacool
Hi im using aimp x64 but there is no directsound option. How can i open it or when it will be ready for it?
Last Edit: October 17, 2022, 08:30:17 by Soolo
Re: When or How Directsound?
October 13, 2022, 08:17:28 »
Карма: +3229/-78
Since Windows Vista, DirectSound is just a wrapper around WASAPI output.
DirectSound is available for compatibility reasons in all Windows until 11.
October 15, 2022, 03:10:00 »
beacool
Im using x64 bit AIMP in wasapi i cant control volume via my keyboards volume controller and it blocks other apps sounds while i listening...
Last Edit: October 15, 2022, 03:24:50 by beacool
October 15, 2022, 10:21:28 »
Карма: +3229/-78
It seems you using Wasapi Exclusive
October 16, 2022, 20:40:16 »
beacool
Nope all of wasapi (push etc etc) settings is the same...
October 17, 2022, 08:29:05 »
Карма: +1408/-191
use
WASAPI: Windows Default
NOT push! NOT event! NOT etc etc!
October 19, 2022, 00:10:48 »
beacool
Am i wrote wrong or did you read right? ALL OF WASAPI OUTPUTS are the same to me i cant control volume via my volume knob!!! It just shows volume meter but not volume up or down. It just mute when it reaches to zero unmute again when i turn just one level...
October 19, 2022, 00:28:41 »
beacool
Latest news...
I just update new version (v5.10.2407 Beta 2 (18.10.2022)) via updater and when i try to get sound from wasapi windows default it says...
File: D:\test.mp3
Code: -2004287480 (88890008)
Message: IAudioClient.Initialize
Format: 96000 Hz / 32 Bit / 7.1 Surround
And it turns russian language by itself...
Edit: I cant change setting 96000hz or 32bit or 7.1 Surround in wasapi windows default
Edit 2: IM USING 64bit version
Last Edit: October 19, 2022, 01:05:38 by beacool
Reply #8 on:
October 19, 2022, 12:27:48 »
Карма: +3229/-78
WASAPI Shared settings can be changed on OS side.
Reply #9 on:
October 21, 2022, 03:51:28 »
beacool
how can i do it?
Reply #10 on:
October 21, 2022, 08:28:00 »
Карма: +1408/-191
Last Edit: August 23, 2023, 14:36:20 by Soolo
Reply #11 on:
October 25, 2022, 06:34:52 »
beacool
Its already like this but problem still same...
