Samba question. Android AIMP
Topic: Samba question. Android AIMP (Read 10370 times)
September 03, 2022, 01:31:49 »
Servidor-correo
Good morning, I've been searching this forum for a similar query and couldn't find it. It is clear to me that AIMP Android has no DLNA Client plugin. I have a Sagemcom Fast5670 router that allows DLNA and SMB sharing. The big problem is that it has been impossible for me to play music from a PenDrive connected to the router with AIMP via Samba. But I can do it with others (VLC, Foobar, etc.). What am I doing wrong? AIMP gives me errors when I enter a Samba folder path from my router like smb://192.168.1.1/sda1/Music/ Thanks.
Re: Samba question. Android AIMP
September 03, 2022, 09:22:16 »
Карма: +3214/-78
What error?
September 04, 2022, 22:15:32 »
Servidor-correo
Thanks for your reply. Attached screenshots of the routes. Neither of the two SMB paths work.
September 05, 2022, 08:45:13 »
Карма: +3214/-78
It seems the app cannot connect to the server or does not recognize samba version. What is samba protocol version on your device? Additionally, please share the logs from the app. Please, refer to the "About" dialog of the app, and check the "enable logging" option. Now, reproduce an issue and send the log file to me.
September 05, 2022, 16:37:50 »
Servidor-correo
Thanks again. I attached log file. I don't know how to find information about this F@st 5670 router. I think that, despite being very modern, it is SMB1.
September 08, 2022, 22:10:29 »
Карма: +3214/-78
AIMP supports for v2/v3 only. Does you router supports for newer version of samba protocol (usually, it can be selected in admin page)?
