[x] [2394] [x32] Sen to tag editor crashes on Windows 10
Topic: [x] [2394] [x32] Sen to tag editor crashes on Windows 10 (Read 11011 times)
July 02, 2022, 23:09:10 »
RaHorus
Hello, sorry in advanced about my poor English. Recentry, I did a clean install of the latest version of AIMP v5.03 x32, and i noticed that the application context menu doesn't work if i try to send a file to the tag editor. I´ve upgraded AIMP from version 4 to latest, and this is the first time something similar has happened to me. The interesting thing is that I tried to go back to version 5.02 with a fresh install and the problem remains, so updating from versions 4 could hide the bug of the tag editor. When I send the files from the Windows context menu, everything works fine, and the errors occur only when I do it from AIMP. If you need any data, please let me know. Best regards.
Last Edit: July 05, 2022, 23:54:15 by Artem
Re: Sen to tag editor crashes on Windows 10
July 03, 2022, 01:34:52 »
Карма: +467/-73
https://www.aimp.ru/forum/index.php?topic=5451.0
AIMP Build?
Bug report?
OS?
July 03, 2022, 16:55:41 »
RaHorus
Windows 10 Pro 20H2 x64 19042.844 WFEP 120.2212.551.0
AIMP 5.03.2394 x32
Sending files to tag editor doesn´t generate dump files, it just opens the software (AIMPate.exe) with no files loaded.
Last Edit: July 03, 2022, 23:54:02 by RaHorus
Re: [2394] [x32] Sen to tag editor crashes on Windows 10
July 05, 2022, 10:24:17 »
Карма: +3196/-76
Please try this build:
https://disk.yandex.ru/d/PrqGv-1Bl1N3xA
Re: [?] [2394] [x32] Sen to tag editor crashes on Windows 10
July 05, 2022, 23:12:54 »
RaHorus
It works great thanks, I will keep testing this alpha and I'll let you know if I find something. Again thanks!!!
July 05, 2022, 23:54:10 »
Карма: +3196/-76
Thank you for testing.
