[x] [1195] URL stream very slow loading time
Topic: [x] [1195] URL stream very slow loading time (Read 10023 times)
May 30, 2022, 21:49:55 »
Klau_B
Hi,
I am listening online radio by using the URL. The problem is that the loading time for the stream is very slow, it takes 12 seconds to load the stream.
The URL's are below(both points to the same radio station):
http://89.238.227.6:8370/
http://stream2.srr.ro:8370/
I am using the latest version of Aimp-> v3.22, build 1195(22.05.2022); Tested on Android 10 and 11.
Is there a way or an option in settings to fix this issue?
You can test by yourself!
This problem is happening only with this 2 URL's. For other URL for a different radio station is working as expected, I mean the URL is loaded instantly.
Maybe the problem is from the radio station? But I don't think, because I used the mentioned URL's on MacOS 12.4(Monterey) in the native Music player and here is working as expected, the URL is loaded very fast.
Thank you,
Claudiu
Re: [x] [1195] URL stream very slow loading time
May 31, 2022, 16:34:52 »
Карма: +3230/-79
Hello,
Please, try this build:
https://disk.yandex.ru/d/qLh-Bo2T_bm5Bg
