synchronise
Topic: synchronise (Read 5067 times)
synchronise
April 02, 2022, 22:34:19 »
Tamutka
Hi,
can anyone help me, please? I am using AIMP in such way: New playlist, and then I insert a map from my Music file (several artists). But when I add some new song in the map, the playlist in AIMP does not synchronize. For instance, if I have 125 song in a map, when add some new songs, the amount in my AIMP playlist is the same, 125. Is there a way to do that automaticly or I have to add new songs manualy to AIMP playlist?
Best regards, Natasa
Last Edit: April 05, 2022, 14:36:49 by Soolo
Re: synchronise
April 02, 2022, 23:43:06 »
Карма: +3230/-79
Use swipe-to-refresh gesture to update playlist's content
Re: synchronise
April 03, 2022, 16:20:35 »
Tamutka
Sorry, cannot understand. On PC?
But I think I found the solution:
New smart Playlist: folders and then in Settings You have to check for changes. And such playlist does synchronize.
Re: synchronise
April 03, 2022, 20:56:45 »
Карма: +3230/-79
Yes, in PC, smart-playlists is a solution.
P.S. I am talking about mobile version
Re: synchronise
April 05, 2022, 14:33:16 »
Tamutka
Thank you.
synchronise
