AIMP for Android v4.30
[x] [2365] Album Art Visualization - album arts appears blurred
Topic: [x] [2365] Album Art Visualization - album arts appears blurred (Read 14325 times)
February 24, 2022, 07:24:03 »
JimFlasch
Карма: +0/-1
Why does the Album Art option for visualization now (as of version 5.02 build 2365) show blurry images? They were sharp and clear before the update.
Last Edit: February 24, 2022, 21:11:50 by Artem
Re: Album Art appears blurred
February 24, 2022, 08:35:26 »
sveakul
Карма: +81/-1
What skin are you using? Is the artwork from files with embedded art, or downloaded from Internet? Just updated today also to 5.02 build 2365 and embedded artwork is just as excellent as before.
February 24, 2022, 18:57:14 »
gr-e
Карма: +169/-3
Can confirm, the album art visualization is blurry in the new build. Interestingly, the opposite happened with the normal album art display: it now shows a much higher resolution image.
Screenshots (embedded artwork):
v.5.00 2344
v.5.02 2365
Skin I tested it with attached.
Re: [2365] Album Art Visualization - album arts appears blurred
February 24, 2022, 21:11:47 »
Карма: +3208/-77
Fixed
February 25, 2022, 03:29:21 »
sveakul
Карма: +81/-1
Quote from: Artem on February 24, 2022, 21:11:47
Fixed
Artem, will the fix be in a nightly build, or has it just been incorporated into the present download for 5.02 build 2365?
gre-e: you're right there IS a difference. I've rolled back to 5.01 build 2357 in the meantime.
Re: [x] [2365] Album Art Visualization - album arts appears blurred
February 25, 2022, 08:09:11 »
Карма: +3208/-77
It will be available in nightly build.
March 01, 2022, 06:10:16 »
Adam
Hello, i notice few days ago that the album art that is embedded to my mp3's is appearing now only in very low quality, 512x512, although the real image is 2200x2200, when there is an external file (cover, folder, etc...) it still shows normally in his actual dimension. Is this a bug, or i' m doing something wrong? I m using the version 5.02 build 2365. Thank you.
March 01, 2022, 08:27:52 »
Карма: +3208/-77
I will publish an update on this week
Reply #8 on:
March 01, 2022, 08:35:24 »
sveakul
Карма: +81/-1
Quote from: Artem on March 01, 2022, 08:27:52
Thanks Artem!
Reply #9 on:
March 01, 2022, 08:56:46 »
Adam
Thank you!
