[x] App won't continuously play a playlist and shuts down after each track
Topic: [x] App won't continuously play a playlist and shuts down after each track (Read 10944 times)
December 25, 2021, 17:30:16 »
blabla
I really hope I can get some help solving this, it's beyond irritating.
Since recently updating the app (on android, it's now v3.20 build 1169) it will no longer play a playlist through, and instead will just play a track or two and then shut down (not even just stop the playlist and stay on in the background, the app completely shuts down).
To go in to a little more detail - when I go in to the app, select a playlist then select a track and play, it will play that track, then shut down. If I press play from the home screen widget (or press play on my headphones) it might play 2 or 3 tracks before doing the same, and if I "interfere" at all by pressing pause or moving from headphones to speaker, it will finish the track it's on, but once that's done, it'll shut down again.
I checked the settings and under "playback" the "jump to next track" is ticked, I unticked and re-ticked, but that didn't help. Just in case I also unclicked and re-clicked both the repeat all and the shuffle (which are both always on), and rebooted the app and my phone, but those things didn't help either.
Am I missing something? This can't be on purpose, because it's too ridiculous for words, so there must be a way to fix it. Please help!
TIA
Last Edit: December 26, 2021, 01:21:26 by blabla
Re: App won't continuously play a playlist and shuts down after each track
December 25, 2021, 23:11:31 »
Карма: +3192/-76
Update to 1171 build, please
Re: [x] App won't continuously play a playlist and shuts down after each track
December 26, 2021, 01:21:02 »
blabla
Looks like that's exactly what I was missing (and god knows why I didn't think to check, d'oh!), I've only given it a quick test now, but it seems to have resolved the issue (but I'll test it longer tomorrow to be sure), thank you so much!
