Playlist not centering on the currently playing song.
Topic: Playlist not centering on the currently playing song. (Read 7381 times)
November 25, 2021, 22:45:15 »
Peffers
Hello.
Firstly, thanks for AIMP, I've been using it as my music player on my phone for a few years and I'm quite pleased with it.
And now for my question: After the latest updates (Currently version v3.20, build 1164, Android version 8.0.0), the playlist doesn't anymore automatically show the currently playing song on-screen; the song is highlighted in the playlist but the list starts from the beginning and you have to scroll it yourself to see the song, while previously it always showed the currently playing song when swiping to the playlist. Is there a setting that I'm missing or is it not working as intended?
Edit. Ok, now it seems to work. I just selected another playlist and returned to the big playlist that has all the music on my phone and now the playlist works as it used to before, although if i select next song on shuffle while playlist is showing, it won't jump in the list to show the song playing but if I swipe right to show the bigger player with album art and then swipe back to the playlist, it shows the song playing, I don't remember if it worked like that before but anyway, problem solved.
Last Edit: November 25, 2021, 23:05:46 by Peffers
