AIMP for Android v4.30
Sort By Folder Modified/Created Date
Topic: Sort By Folder Modified/Created Date (Read 4392 times)
October 02, 2021, 16:04:42 »
KOlmafhen
Guest
Hello, is there any way to sort playlists by
folder
creation/modification date rather than the music file creation/modification date. Thanks.
Re: Sort By Folder Modified/Created Date
October 02, 2021, 16:29:46 »
Карма: +3209/-78
Hello,
Explain your scenario please.
October 03, 2021, 18:14:44 »
KOlmafhen
Guest
I organise my songs in folders and when I want to add a song to a folder I place it inside it, but the problem is sometimes the music i put in the folder has an old creation/modification date which results in the music not being shown at the top of my sort order. Thats why I was wondering if theres a way to sort music according to folder modification date or even creation date if possible.
October 04, 2021, 13:06:05 »
Карма: +3209/-78
It seems strange, because file modification date must be updated on file movement... How to reproduce an issue on my side?
October 06, 2021, 20:09:15 »
KOlmafhen
Guest
Simply copy pasting any file only changes its creation date, cut pasting changes nothing, extracting file from a zip file also changes nothing in my experience.
November 07, 2021, 16:06:07 »
KOlmafhen
Guest
Were my instructions enough to reproduce?
November 08, 2021, 03:21:06 »
verbal
Завсегдатай
Карма: +2/-0
check this topic it might help..
https://www.aimp.ru/forum/index.php?topic=67761.0
