[+] [1137] Songs with Multiple Song Artists only display longest artist name
Topic: [+] [1137] Songs with Multiple Song Artists only display longest artist name (Read 15263 times)
August 07, 2021, 23:37:44 »
Voldrak
I have many different songs with the song artist seperated by a semicolon (the ; character)
These all work and are parsed perfectly fine by AIMP for Windows (Shows both song artists)
but when using AIMP for Android, it chooses to remove one of the artists.
But this isn't done by removing the secondary artist, which would be preferred, but instead it seems to remove this based on the length of the strings.
Whichever string is shorter, gets removed as the artist for the file.
For instance, "AronChupa;Little Sis Nora", it removes "AronChupa", and displays the artist as "Little Sis Nora"
Versus if I edit this file and change it to "AronChupa;Littless", it displays the artist as "AronChupa",
Changing this to add any more characters to the second name in the artists tag displays it as the secondary artist again. I feel like this is a bug, since it tends to usually get rid of the main artist of the song and replace it with the secondary artist, which ends up making it both harder to search for songs (because it removes the main artist), and it also makes it harder to figure out who actually made the song.
This is reproducible with any file by editing the tags, that I have tried.
Also is not skin-dependent (I use Cubic by AJ, but it also happens on Charm and Bliss 2021)
Device: ASUS ROG Phone II ZS660KL, Android 10.
Screenshots:
First one is with the artist name as "AronChupa;Littless"
Second is with the artist name as "AronChupa;Littlesisno"
Last Edit: August 08, 2021, 11:03:47 by Artem
Re: [1137] Songs with Multiple Song Artists only display longest artist name.
August 08, 2021, 11:03:39 »
Карма: +3239/-85
Unlike desktop version, mobile does not support for multiple tag values for now.
Re: [+] [1137] Songs with Multiple Song Artists only display longest artist name
August 08, 2021, 22:16:34 »
Voldrak
Ah, I understand that. Though the main issue here I'm seeing is, at the moment, it just gets rid of the Artist with the shortest amount of characters, which means if I want the main artist to show for a lot of songs, I'd have to modify all the songs metadata and get rid of everything after the ";"
I made the bug report since, most songs are usually searched for by the main artist, and not the artists that are featured, and I thought this might just be a bug in the handling of multiple artists since it isn't fully implemented. I guess I should make a suggestion, in this case, if it's not a bug?
