Skins in the development stage
Kr1eger
[GW+PL] Antares Champagne Edition [AIMP v.4.70]
Topic: [GW+PL] Antares Champagne Edition [AIMP v.4.70] (Read 8808 times)
May 23, 2021, 12:06:43 »
Remoder
Карма: +436/-21
Платформа
: Windows
Версия
: AIMP v4.70 или более новая
Форма:
Горизонтальная
Тон:
Светлый
Поверхность:
Глянцевая, Матовая
Интерфейс:
Hi-Fi
Нашел свой первый проект Антареса и немного его подправил.
Обновил / исправил меню, перенес проект на новую версию, добавил в библиотеку смену цвета.
Last Edit: June 03, 2021, 11:05:58 by Remoder
Re: [GW+PL] Antares - Champagne Edition [AIMP v.4.70]
June 01, 2021, 09:51:04 »
Macrovision
Карма: +1/-0
It's been a while since i saw a HiFi skin in the works, glad to see a new one that's being worked on (even though it's a 3D version of an existing skin). I especially like the speaker animation, can't wait to see this being finalized! +1
June 01, 2021, 13:30:18 »
Remoder
Карма: +436/-21
Finalized version is here >>
https://www.aimp.ru/forum/index.php?topic=53895
This is my first test design, but a smaller scale. I like the spectrum analyzer in this skins. Finalize (maybe) I will not, but then I will add a project file...
June 01, 2021, 14:48:03 »
Macrovision
Карма: +1/-0
Yes, I've been using the current version (with the "flat" speakers) for a while now. I preferred this version with the "3D" speakers because the animation looked a lot more interesting. (also my monitor broke and I had to use a spare one with only 1024x720 resolution, and this one fits) I was wondering whether it's possible to include these speakers in the current version, although since the design isn't being used in the finalized version you probably have a good reason for that
June 01, 2021, 15:46:00 »
Remoder
Карма: +436/-21
Simply transfer the "Kevlar" speaker will not be released, me need to redraw (re-rendered) it (perhaps once).
Although "Kevlar" speaker should be in the original acoustic system, "black-white" speaker option fitted better to design.
Unfortunately I was not able to repeat champagne metal in the new version
> cause - orthogonal view in 3d render for flat design, (then was not accepted to draw in 3d).
Last Edit: June 01, 2021, 17:17:30 by Remoder
June 02, 2021, 03:01:07 »
Macrovision
Карма: +1/-0
Well, that's unfortunate. I liked both designs, really, the only real reason I liked this one more was the speakers. I guess I'll stick to using this one until I could replace the monitor
Kr1eger
