Font size too small.
Topic: Font size too small. (Read 9319 times)
May 14, 2021, 22:56:32 »
tha
Hi.
I changed my "system font" (via Winaero Tweaker) from Segoe UI semibold to Ubuntu medium.
After this the size of some fonts at AIMP appear so small that I can not read them (i mean the fonts of song titles and folders trees).
From this I conclude that System font is related to AIMP fonts. I dont know why but the size it too small , i guess about 4px. Is there a way to fix the size ?
If not , it would be good that bug fix at a future update.
Thanks.
Last Edit: May 14, 2021, 23:09:30 by tha
Re: Font size too small.
May 15, 2021, 00:54:55 »
Карма: +471/-73
Why changing the font not through the system tools should be related to the player error?
You can change the font size in the player.
May 15, 2021, 02:07:22 »
tha
I dont want to change AIMP's font. When i used Segoe UI as system font it was all OK with AIMP.
But now i want to change my system's font to Ubuntu font. Then all works OK except the AIMP.
I try the following settings which are the best with Ubuntu , but still the view is bad.
I set the "
Scale Factor
" to "
Auto
" and the "
text size
" to
180%
. Check the baad result at attached file , cause i cant understand how i can insert the image at my answer. When i click the "Insert image" icon it appears this : [ img ] [ /img ]
Thanks.
May 15, 2021, 02:24:56 »
Карма: +471/-73
If you follow the link in the tweaker, you will find the answer that this functionality replaces one font with another.
You can run into a problem with any program that uses the font you changed. It's not for nothing that Microsoft removed the possibility of this change outside the system settings.
Either you have to refuse to change the font, or carefully select the font to replace and its sizes.
You can also look for the player skin that will use other fonts.
Or create your own skin.
May 15, 2021, 21:09:40 »
tha
1) With the Winaero Tweaker, but also through the registry, you can only change the type of font, not size. Size is standard.
2) The problem with the size appears
only on the AIMP
, not in any other Windows or not application. For this i mentioned as a bug of AIMP.
Anyway , where my current skin is located and what's is the file type of , to try to fix it ?
Thanks.
May 16, 2021, 03:19:47 »
sveakul
Карма: +81/-1
To edit a skin you need to have the project file (*.acs4proj) for that particular skin; these are not always available. If your skin is the default Bliss 4K, you can create a project file for it using the AIMP Skin Editor (see downloads page), and then edit that skin as much as you like, incl. fonts. However, this is not always easy to do. A detailed Help file is included in the download.
May 16, 2021, 03:27:55 »
tha
Thanks , i already try it.
