File: D:\000\testing.wavCode: 1 (00000001)Message: OpenMPT module
OK, I think I found the issue with this. I usually run a newer development version of bass.dll with AIMP by personal choice. I tried replacing it with the version of bass.dll supplied by AIMP, 2.4.15.10, and this does indeed produce the error message and failure to play the wav's. The version of bass.dll I am currently using is 2.4.15.29, which produces no error and it plays. The un4seen developer must have made a change between versions that now facilitates these type of wav's.Try replacing bass.dll with this one and it will work--extract bass.dll from the zip downloadable here:www.un4seen.com/stuff/bass.zip
