Suggestions
DennoN
ADD NEW LYRICS FEATURE FOR STREAM SOURCE
Topic: ADD NEW LYRICS FEATURE FOR STREAM SOURCE (Read 6965 times)
December 25, 2020, 11:04:53 »
ZeroCloud
Because Lyrics feature can only work with a local files which is offline music source, May you can Add Lyrics Feature for stream source
Re: ADD NEW LYRICS FEATURE FOR STREAM SOURCE
December 25, 2020, 15:34:29 »
Карма: +3230/-79
Plugin work for both sources - remote and local, but it requires values from the Artist and Title tag fields.
December 25, 2020, 16:37:54 »
ZeroCloud
I don't think so, because when I trying to edit an information to a music stream source it will be the same like nothing changed, even I saved it, it's because stream file get metadata from the sources and it will replaced what I saved.
or I just don't know how to showed up lyrics properly : (
December 25, 2020, 20:49:17 »
sveakul
Карма: +81/-1
It absolutely will retrieve lyrics from radio streams, if 1) the stream is sending artist/title metadata, and 2) the lyrics web source queries in the aimp_webLyrics.ini file are able to find them. See attached pic. Of course this requires that you have checked the "Find on Internet" box in Prefs/Player/Additional Info/Lyrics.
Because dynamic song streams are not physical files, AIMP cannot "save" anything into them. What you can do is load/save a particular local "cover image" to associate with that particular radio source, which will then be displayed when that specific source is being streamed.
Last Edit: December 25, 2020, 21:03:36 by sveakul
December 26, 2020, 10:56:14 »
ZeroCloud
Thank You 😁, So I just need to open Information Box to show up the lyrics LOL🤣, I suppose post this thread in question section instead of Suggestion 😅
Suggestions
DennoN
