Suggestions
DennoN
Negative delay for radio track splitting?
Topic: Negative delay for radio track splitting? (Read 3403 times)
June 09, 2020, 23:44:58 »
Lurka
Карма: +1/-0
Hi,
some internet radios change track tag after new track has started playing.
Can you implement "negative" delay, using the buffer to split recording few seconds before the tag has changed?
Thank you,
/_urka
Re: Negative delay for radio track splitting?
June 14, 2020, 15:34:43 »
Lurka
Карма: +1/-0
I mean, is it possible to implement an option to anticipate the cut point relative to the track name change?
For example, in the image the cut should be anticipated of 6 seconds, because the track name changed too late.
Thank you and best regards,
Lurka
Suggestions
DennoN
