Suggestions
DennoN
Filter files by relative date
Topic: Filter files by relative date (Read 4005 times)
April 18, 2020, 14:47:59 »
s427
I'd like to create a dynamic playlist (or library template) showing only the files that have been added in the last 30 days.
Another use case: a playlist to play only tracks that have NOT been played in the last week.
But as far as I can tell, when adding a date filter, the only option is to input an absolute date value (eg. "greater than 2020/04/15"). It would be nice to be able to specify a relative date for those filters (eg. "greater than 7 days ago").
Re: Filter files by relative date
April 19, 2020, 21:22:55 »
Карма: +3220/-78
Thanks for your suggestion, I will consider it when planning new version. I have put it to my TODO-list.
April 19, 2020, 23:30:19 »
s427
That's awesome.
Thanks for you great work!
November 23, 2020, 01:42:01 »
Deide
Would be good to have a smart playlist that shows tracks you've enjoyed but not listened to in a while. (ie. Playcount > x AND Last played more than y days/months/years ago)
Suggestions
DennoN
